1 - 6 of 6 Posts
i want to put a TD05 turbo on my WRX wagon. i can instal the turbo my self but i wanted to know how much it would be to tune. does any body know?
TD05 tells us nothing except the turbine size...
What's already done to the car power-wise? What are your compression/leakdown results?
Good news, everyone!
Details, you're missing a lot of them. Also, you're going to need much more than just a retune to use any TD05 turbo.
The car has an intake and thats it. Tdo5 16,-18g I want to know how much it costs to tune it to the car I know there r other things...
Depends on who you take it to. Call around to your local tuning shops for quotes, try to find a reputable one.
Heed their advice by the way. Like I said, there's a lot more to slapping a turbo on a car than just the install and tune, so listen to what the tuner recommends.
Uppipe
Turboback
Reflash
Do that first, then think about a turbo swap (that may be sufficient). They are required for the new turbo anyway.
Before a turbo swap, you should do the two tests I mentioned to make sure your motor is "healthy" enough for it.
Sent from my Droid using Tapatalk
1 - 6 of 6 Posts
