I'm looking at buying a winter wheel/tire set in the coming month to avoid the mad rush once everyone starts worrying about imminent snow again.
The plan is to to buy 17" wheels for winter use only. Likely going with a Sparco wheel from Tire Rack, but not 100% decided on that just yet. Actual wheel is very much TBD-- right now my main concern is tire size.
I'd like to gain a little ground clearance for the inevitable snow/ice packs that always end up on the roads, and to be able to make it through a little more snow than is possible at stock height. The building I work at is on a road that is usually among the last to get plowed (if it gets plowed at all), so any extra bit of clearance helps.
The stock tire on my car is 245/45/18 - 26.7" tall x 9.6" wide.
The other sizes that I've come across in the same range are:
-245/60/17 - 26.6" x 9.7"
-225/55/17 - 26.7" x 8.9"
-235/55/17 - 27.2" x 9.3"
-225/60/17 - 27.6" x 8.9"
-245/55/17 - 27.6" x 9.7"
-215/65/17 - 28.0" x 8.5"
-235/60/17 - 28.1" x 9.3"
The problem I'm having is that I can't find anything on the biggest diameter tire that will fit on a stock height 2015+ WRX (mine is a 2017). Ideally I'd be considering the 215/65/17, 235/60/17, and 245/55/17 sizes-- but I'm not sure if they will fit. It's not a huge jump in tire size-- 1.3" bigger overall for even the biggest of those three-- but I don't know how much of an increase the WRX can handle without any rubbing.
Has anybody had any luck going up in size? Or has anybody read/heard anything about the tallest tire that will fit? I've done a ton of searching and am at a loss here. Obviously this isn't urgent seeing as it's going to be 90*F here in CT today and tomorrow, but the sooner I get the winter set ordered the sooner I can relax and enjoy the fall.
Thanks in advance...
