1 - 7 of 7 Posts
well while my wrx isn't insured and registered i figured it would be the best time to do some work to it. not that it needs any of these things but when i was thinking wingless i was thinking of this stuff too. but just an idea for now until i figure out if it would work..
1.question is would 2004 to 2007 taillights fit and work in a 2002 wrx?
2.are the trunks interchangeable between those years?
3.and then the bumper..if i got the newer taillights i would need the newer different bumper? for where the newer tailights have the half circle thing in them at the bottom.
...and would this bumper just bolt up?
thanks
1. Yes, they will fit with the 02-03 bumper but will stick out slightly on the inside bottom corners (nearest the trunk). It is hardly noticeable and in my opinion they are still way better than 02-03 tails
2. Yes, anything 02-07
3. As said before, you could keep the 02-03 bumper but changing to an 04-07 bumper would give you a better fit. Yes it should just bolt up.
No problem. If you want some pics of 04-05 tails on an 03 with stock bumper and trunk let me know. I've now run, 03, JDM V8 (04-05 style), 07 and soon to be modded 07 taillights
yeah could i see some pics of that. cuz i think i might go 06-07 tails but still trying to find the wrb 06-07bumper. so i might be stock bumper for a bit
Well i can't find any good pictures showing the slight lip caused but here is one that shows how unnoticeable it is. I can take a pic of how they sit along the bumper if needed
Discussion Starter #7
damn you cant even tell unless your looking for it. thats not bad at all. thanks again. are the newer tails plug and play?
1 - 7 of 7 Posts
