im at the 3k mark and im thinking of making the switch to synthetic. what brand, type of oil do you guys reccomend, and why?
thanks yall
-Robert
thanks yall
-Robert
Mobile 1 is the choice of Prodrive's Impreza WRC. Therefore it is the choice for my WRX.Able Knight said:Which is better...Amsoil or Mobil 1?
Mobil 1 is also much less expensive. Both use a PAO stock anyway.dark_rex said:amsoil says they are better
mobil says they are better.
i say they use the same molecular formula and principals.
i use mobil one.
its 6 of one, half dozen of another imo.
dR
Almost twice as expensive. However, you can go longer between intervals. I change mine every 5000 as opposed to 3000. I know Subaru says every 7000 but I don't buy that. Yes, you can get Mobile 1 at Subaru, just tell them, but you MUST make sure that Mobile 1 is all you use from there on. You can't go back to convensional oil.DoubleYourX said:What does it cost compared to regular oil and can I get it with a regular oil change at my local subaru dealer?
switching to synthetic next change would be your best bet. breaking it in with non-synthetic is the bestPenguinking said:well, i just got my oil changed with conventional, so does that mean i can't ever use synthetic???
im only at 3000 miles right now, so is there room to work with?
Who said that? You can go back to conventional Dino juice, it's just recommended that you drain it all first.koyokid said:
