1 - 2 of 2 Posts
I just picked up a 2006 wrx transmission with LGT gears, rear diff to match, axles, clutch, but it has the push style going towards the fire wall where as my oem 2004 wrx has the pull style. With all the parts I think it’s a direst swap over either way, just use the clutch from the 2006. Is there anything I should be aware of? Will my 2004 wrx oem drive shaft work for the new 2006 wrx transmission and diff.
Did you get this sorted out? I just picked up an 04 wrx transmission to put in my 06 wrx and I'm just learning that the final drive ratio is different, I thought I just needed axels...
1 - 2 of 2 Posts
