1 - 3 of 3 Posts
I have an 04 wrx wagon. I want to tighten up the suspension, rid the car of the body roll, etc.. I am thinking of doing the following;
Front and rear sway bars
Front and rear springs. I have decided against going with a coil over setup due to living in Tahoe and I don't want to lower the car too much.
With doing the springs alone;
1. Is this a BIG improvement over stock and wort the money?
2. What other parts should be replaced when doing the springs. I have been searching and reading about changing bushings, struts, etc.. I'm not very technical, just know what a tight car feels like-and I want one!
thanks for your time.
court
A rear strut tower brace significantly stiffens the wagon body. I noticed the difference as soon as I drove it after install.
First thing should be good rubber. Then swaybars, get a set that meets your needs. A rear sturt bar, like stated above is money weel spent on a wagon. When doing springs, I would do the struts also. New Group N top hats will help stiffen thing ups.
Check out http://turninconcepts.com/index.php?cPath=1_9 they have many kits to help stiffen things up.
1 - 3 of 3 Posts
