1 - 7 of 7 Posts
i am installing 07 sti springs on 02 - 03 struts. i have the needed strut tops and strut spacers. my question is where do the spacers go in the assembly, will they be under or above the strut top?
Moderating on the run!
they slide over the threaded strut shaft and then you put the strut top on- they simply take up the slack that occurs when using 02/03 style struts w/ 04+ tops- w/o them you'll get clunking
thanks, i got everything taken care of yesterday. now i ride on tokico hps with 07 sti springs. rides great, not a lot of drop but much better ride imo
not a lot of drop, but then again you don't want a lot of drop w/ a MacP strut
you've got a good bump in spring rates- close to 40%, that and more damping on hand should make for a nice combo :)
Where do you get the spacers?
Thanks :thumbup:
1 - 7 of 7 Posts
