Here are the teaser pics.
I bought them at www.achtuning.com in Redmond. They got them in really fast. They are an authorized Stoptech dealer which means they can not sell them lower than what stoptech has told them to do BUT the owner told me he would give you guys a good deal on the kit. If you buy from him he will throw in free rear stainless lines, 2 bottles of Motul brake line fluid AND a Achtuning T-shirt. (made by the same guy that made the wcss shirts, Mike)
Anyway, here is what he emailed me to tell you guys.
Stoptech WRX Big Brake Kit $1695
Free Rear stainless lines
Free Motul 600 high temp fluid (2 bottles)
Free Achtuning T-shirt
Red calipers are $200 more
And heres some more info on the brakes (taken from stoptech.com)
Subaru Impreza RS 93-99, Impreza WRX 2002+ Big Brake Kit - Front, 2 Piece Floating Directional 328mm x 28mm AeroRotors, Drilled or Slotted, 4 Piston ST40 Calipers,7075 T6 Billet Aluminum hats, Stainless Steel Brake Lines, AXXIS Ultimate Brake Pads - Black Anodized Calipers. Requires 17 inch wheels
*Dramatically Increases heat capacity of front brakes.
*328 mm x 28mm high performance AeroRotor™
*Floating two piece rotor includes hat system using billet
7075 T-6 hat - eliminates distortion.
*Innovative anti-rattle hat mounting system -
minimizes noise and knock-back
*Slotted or drilled finish available for outgassing and
better pad bite.
*High performance 4 piston aluminum caliper with
differential bore and dust boots - sized specifically sized for the Subaru WRX.
High perfomance pads included, racing pads available.
Front stainless steel brake lines included.
And I weighed everything...here is what I found.
stock
rotor 14lbs 6 oz
caliper 13lbs 12 oz
Stoptech
rotor 13lbs
caliper 7lbs 11 oz
That is for each side! So you will save appx 16 lbs with this brake kit.
better pad bite.
stock
rotor 14lbs 6 oz
caliper 13lbs 12 oz
Stoptech
rotor 13lbs
caliper 7lbs 11 oz
