1 - 9 of 9 Posts
Discussion Starter · #2 ·
for those of you who don't know and want to, i found the ride height of the wrx wagon. went to the movie theater and wen up and down the parking lot to find a wagon. so...the front height from fender to middle of rim is 15" and the rear from fender to middle of rim is 14.5" if someone else found a different measurement, post it. :) i would like to know if anyone got a different height cuz i could've made a mistake.
Moderating on the run!
Wagon- measured from center of hub to fender lip, front- 387 mm +/-12mm, rear- 376mm +/- 12mm
Make sure you are are on a Very level surface or your measurements are for naught.
Big Sky
tundra said:
I saw this post and am looking for the same dimensions on a stock WRX sedan. Can anyone help me out?
Basically looking for center of hub to the bottom of the fender. Thanks ahead of time for any help :)
-Matt
396/376 sedan
That's what I posted above, not noticing it was a wagon- someone in heaven is making me look good (or maybe it's Chris- thanks:) ).
Big Sky
tundra said:
Thanks for the info!
I measured it when I first got the car, but in typical fashion can't find where I wrote it down, haha :)
-Matt
Inches, millimeters, blah blah blah...
I use the "finger" method :p My car went from "3 loose" to "2 tight".
1 - 9 of 9 Posts
