1 - 9 of 9 Posts
Hello,
My '19 STI did not come with factory fog lights, basically, just the black panel shown below. I want to install factory fog lights but I can't seem to figure out whether or not I can since the wiring is not there. I ran several searches online and I'm having a hard time finding an answer. I've even looked for aftermarket kits but I'd rather use OEM parts. I also tried locating individual part numbers for the fog light kit H4510VA040 but I'm not having any luck.
Any advice about this will be appreciated. Thanks!
You'll probably have to buy the harness as I think the option is missing from the switch as well.
On Volkswagens it was as easy as replacing the switch and wiring from the harness to the fogs.
Thank you! I was able to locate some part numbers out of a review for oem-replica fog lights. Someone did the same thing it seems. They got the cheaper fog lights and bought the oem wiring and such. I already bought a set of yellow led Morimoto fog lights from Retrofit Source.
I'd keep an eye on that card. Subispeed has had persistent problems with stolen CC info.
Hello,
I had thre dealer instal the factory set, with wiring and switch,,,,,then replaced the shoddy OEM bulbs for LEDs - all good.
Off topic, but does anyone know if there is an aftermarket plug-n-play set of yellow LED fog lights available for the current WRX. Ijust bought a 2020 Limited which has factory fogs, but I want to upgrade to high quality yellow ones. Baja Designs offers them for trucks, but I don't think they offer a direct fit set for the WRX.
1 - 9 of 9 Posts
