1 - 2 of 2 Posts
Hey all,
A while back I bought an old school GReddy Type S blow off valve for my WRX, not doing much research on whether it would be a simple install or not. It came with a flange that was supposed to be used for welding onto an aluminum pipe so I spoke with one of the guys from ETS asking what pipes I should replace and instead I was directed to figure out what the tube size is on the stock bov so that I can find a push in adaptor that fits instead.
Here is what I was told = You will need something like this: https://www.ebay.com/itm/32mm-1-25-...-Fitting-Fits-GReddy-S-RS-RZ-FV-/351292387328 - I don't think that is the correct size. You will need to measure your stock BOV and see what size tube it uses.
I thought I'd ask around to see if anybody knows in the hopes of maybe saving a little time.
1 - 2 of 2 Posts
