vidsolve said:
where can i source all the koni setup you desc- where is best places to get that, and do i need tophats also for this setup?
Tophats are rubber wear items, so depending on the age, they may need to be replaced. While the assemblies are already out of the car and apart is the easiest time to do said replacement. Every time the strut assemblies come out of the car, you need to pay for an alignment. You could always have the tophats available to you, and make a game time decision; if you choose not to use them, sell them for what you can and take a small loss. Personally, if you're going to go with Koni / RCE setup, I would at a minimum replace the fronts with Whiteline Com-Cs for the increased caster, and decide on the rears based on price. You can get OE from the dealership for not too much money, but you can also go with Group-N which will be a better fit for that setup. Ultimately, it's up to you, your budget, and your realistic goals/uses for the car as to what you should buy. When I have to replace parts, I always look for the ability to upgrade when I can.
NOTE: My Subaru is a toy, does not serve as a daily driver, so when I replace parts, I focus on the spirited / mountain driving I like to do. I'm not worried about NVH or other things that people who need to live with it on a regular basis would.
