1 - 4 of 4 Posts
Test drove a beautiful lapis blue 2020 WRX premium and I loved the look, the color was exactly what I dreamed off, but the clutch was stiff as a rock. Does this become less stiff as once the car is broken in or once the clutch is worn out a bit. I assume this wont be an issue in the long run for those are become accustomed to it but out of curiousity. Does it stay the same?
The clutch is stiff stock but you will get used to it and it will eventually loosen up a bit as breaks in. My 2017 wrx was the same way.
The first time I drove a Subaru was two days ago when I bought my WRX and the clutch mechanism was definitely different from anything I've driven before. To me, the clutch release point was extremely high and you had to give it a fair amount of gas or else the motor would bog.
1 - 4 of 4 Posts
