1 - 2 of 2 Posts
So, on my 2013 wrx limited I changed my brake master cylinder with a new one and after I installed it I noticed when I took the car home the brakes were dragging which didn’t happen before. Did I do something wrong? Is there a part I missed? I’ve tried bleeding the brakes, lubing the pads from any metal to metal contact. Also, i DONT know if this may be the problem but there we a second metal tab on the brake pads and it wouldn’t fit in the caliper so I cut it off. Would that be the cause of this?
You either had the wrong pads or installed them improperly. That's likely your issue.
1 - 2 of 2 Posts
