1 - 5 of 5 Posts
ok if m a dumbass point me in the right direction
Does this lower the car any?
And is it really worth 1k? or should I jsut get a set of springs and KYB's?
Discussion Starter · #3 ·
daily driver, probably wil never see the track, and maybe the strip once in a while
well if ur looking to drop it a little buy some aftermarket struts and throw on some eibach's. better suspension setup is the end links, sway bars, and mounting brackets
Someone else is posting on this same topic...and it's current...have a look see.
I would totally get the Sti set-up for $1000 if I could afford it. It barely drops the car so you shouldn't get it if you want a "low car".
1 - 5 of 5 Posts
