c'mon man....give us the physics!!! the suspense is killing me, that makes total sense, and actually was what a was suspecting to be the case, but can't quite figure out exactly how this principal works (not meaning the cap specifically), nor the value of having higher pressure in the cooling system. it's kind of like fifth grade math class here now....to get credit you must show your work.djrez4 said:if you're talking about the radiator cap, it simply holds more pressure.
at higher pressure, it takes more heat to overwork your coolant system. it's a bit more complicated than that, but that's about it.
well garsh....ya make it sound so boring and sterile!pace said:PV = nRT
V, n, and R will remain constant. So, if your cap can hold more pressure, then the coolant can have a higher temperature without 'boiling'.
-Pace
hey pace....i have upgraded my suspension and tires....wanna go for a drive?![]()
You sort of have it right. The STi cap allows for higher coolant temps because it can withold more pressure. That's all.cobra117 said:I would think that wouldn't apply to the situation so well... I thought that only applied to gases... Because if you think about it... if n and R are constant... if you increase pressure on the gas, the temperature would have to rise because volume cannot decrease (Incompressible liquids). Ugh, nevermind, I'll look it up. =)
its funny how equations relate to other fields. in finance, those same acronyms would meanpace said:PV = nRT
-Pace
....not really...dark_rex said:its funny how equations relate to other fields
I ran the Golden Gate with my buddy on his R-6 a few weeks ago. Some nice new sticky tarmac on the lower portion of the canyon.
-Pace
