1 - 8 of 8 Posts
Hello guys,
I have a '07 STI which had major engine problem a few weeks ago. I'm in the process of rebuilding it.
I already purchased CP pistons (Stock CR and bore), Eagle H Beam Rods, Cosworth Bearings, a Walbro fuel Pump and an ACT Street clutch. I have to buy a nuw turbocharger (yes, it was that bad) and I'm thinking about a Blouch 18G-XT. I already have a Perrin 3¨Turbocback exhaust and an Accessport V2.
As I understand I'll need bigger injectors, and a friend advised me on getting top feed ones, although I rather stay with side feeds in order to be closer to stock configuration (!). My question is, how big I need them to be? they recommended me 550cc, but everything I read have 650cc upwards. I don't want to have driveability problems since it is my daily driver, even if I don't drive a lot during the week, but I want to buy big enough to achieve my combination's potential.
Any help will be appreciated.
BTW, Fuel consumption is no trouble at all since I live in Venezuela and here 95 octane gas is cheaper than mineral water :tongue:.
Best regards,
Guillermo Sanchez
Welcome. Sorry to hear about your troubles.
Both size injectors you mentioned would be too small for the 18G-XT turbo; they may work, but you'd most likely run out of injector and leave power and safety margin on the table.
If you go to deatschwerks website they have a calculator on their website that will tell you exactly how much fuel you need. I would say 850cc should be more than enough for your purpose.
Discussion Starter · #5 ·
Hello again and thanks for the useful suggestions.
I finally called Blouch Turbos and they recommended me 740 cc injectors, so I guess I will buy 750's.
Thanks Again!
Guillermo
Discussion Starter · #6 ·
Injectors
One more question guys,
Are the 07 STI injectors top feed or side feed?
I understand 06 and before are side feed, I just want the same type as it is installed in my car from factory.
Thanks for your help,
Guillermo
1 - 8 of 8 Posts
