1 - 4 of 4 Posts
Hello I recently got offered a STI intake manifold and injectors and everything that comes off a stock sti for free. My question was, would it be worth doing the swap, and is there anything else i would have to swap other than switching my throttle body since i dont have the fly by wire... thank you
Nobody can answer correctly without knowing the model years of the donor and recipient; however, from what you have said your car is likely a 2.0L WRX. The manifold won't help. Get the turbo, IC, injectors, interior, gearbox, steering, and suspension instead.
It will do absolutely nothing as they are the same design and you cannot use a DBW throttlebody. You get pretty red paint unless you use a JDM V8 or V7 intake manifold which for a 2.0L cable driven tb as it deletes the TGV's
I will swapping the manifold and injectors because i think one of mine are bad, my recent posts have been on the cyl 1 misfire soo i figured since it was free it would be okay to just swap he whole thing. 02 wrx
1 - 4 of 4 Posts
