Hi,
I have a problem reading my ecu rom with Ecuflash using a tactrix open port 2.0, I connect the tactrix to the obd2 open romrainder and I can with logger read CEL codes, but when I want to read the Ecu ROM with Ecuflash the port close error on the logs show up, I connect the two green connectors one was I don't know why or who was cut, so I just jump both with a wire see pic attached, then I search for the white flash connector but without success I just find a black connector right next to the green connector so I try to connect the white reflash plug from tactrix and doesn't fit so I just connect two wires to the both sides (see picture attached) when the green connector is wire the check engine light flash and the radiator fan stars and off, start and off and so on, but ecuflash keeps failing to read the Ecu rom, anyone came guide me how to troubleshoot this? Thanks in advance folks.
Sent from Tapatalk
Sent from Tapatalk
