I GOOOOOOOOOT IT!!
Stand by for test and thoughts... If I don't notice anything I'll set my car on fire and post a vid. That was some serious PITA work!
edit below
OK so after spending way too much time doing that i finally have some "final thoughts" if I may...
The install
to pull everything down it literally took me 15 minutes. And that included 5 minutes of me realizing i had no idea what the directions meant at all. Once I got under there and figured out what was what I was ok.
It took about another 15 minutes to remove the bushings. Again to see it really helped me when comparing what was underneath to what was in the directions.
It took from 12:30 to about an hour ago to get back together. I had stripped the threads on the final bolt on the passenger side. I also wanted to straighten my steering wheel which was a degree or two off. I finally drilled it out, and got the last bolt to work. F what a PITA. BUT I will say, its a noticeable difference. I am surprised when people say they dont notice anything. there is 0 play in the steering wheel. and i mean ZERO. if you turn it 1/4" to the right it will turn. its crisp, tight, very responsive. There are curves and such i am used to taking that i have to "re-learn" i almost put the car in a ditch.
There is also a stretch of road that has some bumps in it, and if you really give it gas the car will hop left to right. This took the wheel hop right out of it.
I think if you can avoid some of the issues I had, i would say do it asap. It really improved the handling of a car that I feel is the best handling car I have ever owned. And I Have owned a bunch. Even better than my 1980 Dodge Colt
I am extremely pleased and really glad I did the work!
