1 - 12 of 12 Posts
Discussion Starter #2
Ok here is another question if there is not a reciculation kit for the hks bov . i was reading that you can plug the hole..will this make the car run the same as if i was running a recirculation kit? thanks for all your help
Yes they do make a recirculating kit, I have the piece for it but then I got talked out of BOV's and never installed it...when I get home from work I'll take a picture of the piece.
And no if you "plug a hole" it won't work like recirculating...there needs to be a tube directing air coming off the bov for the ecu to measure, only then will it be "recirculating."
thanks SERacing do you remember were you got it? and you siad it is for the hks ssqbox right? thanks again
Wrek
Theres a part on the bov that basically is open...its bullet shaped, and at the end theres a hole where the air passes out of. Now the piece I have goes into that hole and you put a piece of hose around it and it acts just like the stock bypass valve.
Not loud at all...will just make an echoing sound. Don't know how to explain it...I posted a link awhile ago from an Evo with the Recirc kit on it. W/o its a loud "shreek/whistle" and w/is a fluttering sound. I personally like it recirculating.
1 - 12 of 12 Posts
