1 - 3 of 3 Posts
having a little annoying noise when i press on the clutch it squeeks, i assume its a easy fix like putting on a little lube but not sure
you can try lubricating the pivot point up under the dash on the end of the clutch pedal however i can also say that the release bearings on some of these have made some noise and I have had to do more than one under warranty ( im talking about the 09-10 WRXs of course). What year is your WRX? So from what your saying I believe its either your pivot point on the clutch pedal, the release bearing, or the clutch fork where it connects to the release bearing is lacking lubrication...
1 - 3 of 3 Posts
