1 - 20 of 25 Posts
so anyways, i put in some Boston acoustics components in the front doors, powered by an amp under my seat, everything was cool. when i added my basslink, i ran thicker power wire (4 ga) to under my seat, then split the wire (dist. block) 1 to the basslink 8 ga, and one to the amp for the bostons 8 ga. now with the music low, i get a REALLY annoying whine from my passenger tweeter than corresponds to RPMs. not TOO loud, but i can hear it. now, i don't have any powers touching any RCAs, what else could possibly make this happen? please respond
A bad ground could cause this. Make sure all units are grounded well to the chassis. Also check metal trim on the RCA cables that could be making contact to other metal that isn't grounded properly. If none of this helps, try switching the RCA cables at the amp end to see if the noise changes to the other speaker. This will tell you if the noise is coming previous to the amp or internal. That might be a good first step to give you a better idea of what to attack first anyway.
Discussion Starter · #4 ·
thanks, i'll try that, anyone else?
Leave the engine off when you want to listen to music. j/k. Yeah I agree with the previous posts, especially check the grounds. Also check to make sure the RCA's are not pinched.
G
Common problem called alternator whine ;-) ;-) (i work @ a car audio store). All you have to do is get one of these:
http://www.crutchfield.com/cgi-bin/...p?i=127ANS80&id=morephotos&a=&s=0&cc=01&g=780
And it should fix your problem
Get it after you check all the grounds first...if the ground fixes it you should be all set. You can also try a double ground, where you split the grounding cable and find 2 ground points....thats always a good idea. Good luck!
Discussion Starter · #8 ·
thanks for all the suggestions guys. i still haven't done anything about it yet cause i'm too lazy to lift the seat up, (i grounded the amp to the left rear bolt that hold down the drivers seat) made sure to sand it down first. its the same place i had it grounded before, only then it was fine. question: would having a power wire near or touching the ground wire cause this problem? cause the power is crossing the ground at one point i believe
G
Well if the power wire was touching the ground wire, ud have sparx all over the place and could start a fire so thats bad. Let us know how it works out.
Discussion Starter · #10 ·
it would spark even if just the plastic wrapped parts of the wires were touching? i'll definetely try out that ground though.
G
oh no, jstu the wires themselves would ahve to touch. ANd u can run ground and power right next to each other, thats not a big deal...i do it all the time......
My stuff's taking forever to get done...Alpine takes forever to fullfill an order :-(
I WANT MY BASSSSSS
Discussion Starter · #12 ·
i used to have a alpine typer 15, and was puting 300 rms into it. it sounded very nice, then i decided to be a wise as$ and step up the power to a RF Power 1100a²:rolleyes: blew that alpine up in a weekend. had to switch to the big dog RF power 15". SQ not as nice, but man did that shiot POUND. now i don't want anything near as big or heavy, so the basslink is just fine for me now. free bump for me as i'm still selling the amp if you know anyone interested.
Get something called a "Ground Loop Isolator" they sell em at radio shack or at crutchfield. They're about 15 bucks, and get rid of the exact problem you're talking about. They go in between the RCA's and the amp.
Discussion Starter · #14 ·
i may have to look into those. thanks, are they just an extra wire, or a big boxy thing? i tried undoing the ground, moving it to the tranny mount hole, no luck. this sucks:(
Discussion Starter · #16 ·
well, went down to radio shack today, bought a GL isolator, and no luck. it's still whining. only from the right (red) RCA cable. if i switch it, the noise goes to the left speaker. would this be an indicator of a bad cable? or something else?
G
Make sure the wire isnt pinched anywhere (best way to check this is grab a set of long rcas, dont ahve to be mosnter or anything, jstu ranom rcas, and run those from your head unit to the amp to make sure its not the rcas.
your right RCA behind the deck could be "touching" something behind the dash. Also, might be a problem with the deck itself. I would try the RCA outside the car route.
Discussion Starter · #19 ·
im gonna see if plugging the RCA's in behind the HU will do anything. it only whines sometimes. other times, it's quiet, maybe it's rattling and hitting something. thanks tsunami
no problem. Used to deal with these issues a while back. This was before the days of high voltage decks. Hope it helps...
1 - 20 of 25 Posts
