Hi all
Few months ago we are decided go route of 2.1 stroker with "few" others mods and after 1 year here is almost finished project(just need sort the few bits)
Engine:
2.1 SBR JDM WRX with AVCS built by [email protected] Racing:
Cosworth pistons
Manley Rods
ACL Race Bearing sets:big end and main bearing set
Cosworth baffled sump
10mm Modified Oil pump and water pump
12mm ARP Headstuds
Cosworth Stopper 1.1mm HG
79mm Subaru V8(EJ257) Nitrided Crankshaft
Cosworth timing belt kit
Heads(Valves re-lapped,cleaned,re-shimmed and head skimmed)
Engine painted black
Engine Dress Up:
Powder coated Header tank
Powder coated Alternator
GT-Spec Cooling panel
HKS Billet Oil Cap
Blitz Header Tank Cap
Lightweight pulley set
Alloy Radiator
Oil system:
Setrab Oil cooler
Cosworth Baffled sump plate
OE Sump
Baffled 3-port Oil Catch Can
Induction/Turbo and Fuel system:
840cc injectors with Fuel Lab FPR and Fuel Lab Billet Fuel Filter
Modified WRX CDF Parallel Fuel Rails
Braided Fuel lines with AN fittings
340LPH HRC Fuel Pump
Spec C Inlet manifold custom powder coated(black)
MDX 321T Billet(GT30 based turbo) with Zircotec Ceramic Coated exhaust housing
3port Prodrive boost solenoid
RCM V7 Big cone
3"HKS Ti Cat Back Exhaust with Hayward and Scott downpipe
GT-Spec Headers with 3 bolt upipe
NOS Sniper wet system(25-50bhp jet,still not running due issue with wiring)
Custom hard inlet induction hose heatwrapped with DEI
Custom FMIC with painted IC pipework and heatwrapped with DEi Heatwrap(black)
ECU/Battery:
Syvecs ECU with 8 switchable maps ALS and LC enabled(1st: 1.0bar V-power ,2nd:1.4bar V-power,3rd:1.7bar ALS+LC,4th:1.7bar V-power,5th:1.7 bar V-power +20%methanol,6th:1.4bar V-power +20% methanol with ALS,LC,7th:1.4bar V-power+20%methanol,8th
Odyssey PCS680(fitted in boot)
452.2BHP/440lb-ft on V-power
490.2BHP/480lb-ft on V-power and 20% Methanol
Brakes:
FR K-sport 8pots 356mm with Ferodo DS2500
RR K-Sport 6pots 330mm with Ferodo DS2500
HEL braided lines
Suspension:
HSD HR Coilovers
Front Solid CDF Droplinks
Eibach ARB FR 22mm & RR 24mm
Hardrace Adjustable Lateral Links with ball jointed rear drop links
Whiteline Anti Lift Kit
Cusco Front and Rear Strut brace
4 point underbrace(STi pink)
Wheels/Tires Modifications:
Vredstein Ultrac Sessanta 245/40 ZR18
ROTA Grid Drift 9.5x18” ET38
Blue anodized wheel nuts M12x1.25
Track tyres/wheels setup:
Toyo R888 255/45 17
Drag DR31 9JX17"
Interior/Exterior Modifications:
Interior:
Full late V8 dashboard(fully flocked ) with Late V8 HVAC
Race Technology Dash2 with Syvecs CAN ECU interface
Sparco EVO 2 with Buddy Club rails-Driver side
Sparco EVO 2 with Buddy Club rails-passenger side
STi door cards
STi Alloy pedals
Sparco gearknob
Short shifter
TRS 4 Point Harness
Sparco 310-SP Steering Wheel
Shadow gauge set(Oil Temp,Oil pressure,Water Temp and Boost)
Defi style Gauge pod Flocked
ATi steering gauge pod with Autometer NOS Gauge and AEM Uego AFR gauge
EGT gauge
Life-Line Mechanical 2.25Kg Extinguisher Kit
Alpine Audio
Exterior mods:
Chargespeed Front bumper with Chargespeed Carbon Ducts
STi fenders
JDL rear lip
Chargespeed Sideskirts
OE Bonnet with WRX scoop
JDM HID lights
JDM Grill
Hella Supertone Horns
Custom Diffuser
here are some pics
Old spec interior without the DASH2(digital dash):
Unfinished interior with DASH2:
Engine bay:
Thanks for any comment
Jura
Engine:
Cosworth pistons
Manley Rods
12mm ARP Headstuds
Engine Dress Up:
HKS Billet Oil Cap
Alloy Radiator
Oil system:
Setrab Oil cooler
OE Sump
RCM V7 Big cone
ECU/Battery:
Brakes:
HEL braided lines
Suspension:
HSD HR Coilovers
Toyo R888 255/45 17
Drag DR31 9JX17"
Interior:
STi door cards
STi Alloy pedals
Sparco gearknob
Short shifter
TRS 4 Point Harness
EGT gauge
Alpine Audio
Exterior mods:
STi fenders
JDL rear lip
JDM HID lights
JDM Grill
Custom Diffuser
here are some pics
Engine bay:
Jura
