Solenoid problem
713 Views 1 Reply 2 Participants Last post by  WRX-maniac
Hey guys, what's going on. Got a small problem here and wasn't wondering if I can get some input. Recently bought a 2004 wrx that has a turbosmart MBC. Now the car isn't tuned so to be on the safe side I want to go back to the stock solenoid. Small problem, I need the "T" that connects the 3 hoses(compressor nipple, actuator nipple, and the solenoid itself.) The car is also giving me a p0244(Turbocharger Wastegate Solenoid A Circuit Range/Performance) so i thought it might be because of the MBC. Anyways what I wanted to know was can I use any T connector that I can find to connect the hoses? Or does it have to be the stock connector? Thanks for the help!!!
1 - 2 of 2 Posts
Technically you can buy hose and a T from any autoparts store as long as the diameter is the same as the oem hose. Where your problem will be is the restrictor pills. Each side of the T (one goes to the turbo, the other to the wastegate) has a specific sized restrictor pill. You can buy the complete set for the T clamp and hoses directly from Subaru. That way you know it is the correct size everything.
Here is the link to the parts directly from Subaru: https://parts.subaru.com/a/Subaru_2...02_6021245/AIR-DUCT-02MY-05MY/G11-073-01.html
Within that diagram you would need all of the parts on the left hand side that make the "T". Here are the part numbers:
-H40306 (hose to wastegate)
-22315 (the T)
-0953S*B (hose to turbo)
-22326 (restrictor pill that goes in turbo side hose from T)
-0953S*A (hose from T to the turbo inlet)
-22314 (vacuum hose connector that goes from turbo inlet to hose listed about-0953S*A)
This may seem daunting, but it pretty easy to do. The hardest part is running the line from the turbo inlet under the intake manifold and to the turbo.
See less See more
1 - 2 of 2 Posts
