So im going to go straight forward to this question that its bugging me a lot !
Lets take for the sake of this example a simple upgrade to your car, lets say a high flow filter system that will increase some HP allowing more air to the engine.
-If i introduce more air into the engine that means that i am changing the compression ratio.
-A bad compression ratio leads to engine failure (long or short term i dont know but i does)in this case it would be a lean mixture.
-The ECU of the car most likely will not compensate for this engine upgrade meaning that it will read the air intake ratio as if no upgrade was done (which is bad).
-If you want to compensate the extra air (that is eventually going to the engine much faster thanks to the upgrade intake system) you need extra fuel, the fuel system is designed to inject fuel at a certain rate and speed. Chances are that you need to reprogram the fuel system to get the right ratio.
-will the engine hold this new compression ratio ?
I might be wrong in some points but why would anyone want to modify a cars engine if so many things will go wrong if not professionally tunned ? and even so you might still face some other issues.
