should i get a boost,air flue,and oil, gauges, or should i just get AP. it tell u all that on the AP no?
O and the car is a 2010 WRXSome of it depends on what car you have.. with GD and GR chassis cars the only one you can read on an AP is boost. There is no WBO2 (AFR) or oil pressure/temp sensors on the car stock. I have aftermarket boost, WBO2, oil pressure, EGT, and ethanol content gauges (planning on adding oil temp and turbo shaft speed sensors in the future).
Whether you should actually bother getting aftermarket gauges depends on what you want to do to and with the car. If you're leaving the car stock and using it as a daily driver then I wouldn't spend money on gauges.
that what i was doing but cant decide if i want analog or digitalYou'll have to run lines for sending units for most any gauge. Digital or analog.
Personally. Afr, boost, oil pressure.
As far as I know wide band AFR gauges only come in digital form.. it would be really hard to glance at an analog AFR gauge while doing a pull and see was that 11.2:1, or 11.5:1. Of course you won't ever be able to see all the info you need for tuning even if you stared directly at the gauge the entire time (which wouldn't be very safe). You will need a logging cable to make the wide band useful.
As far as boost and oil pressure go, it's up to you. You don't need to know what your oil pressure is down to 1/10th psi. If you can see it's within 4-5psi of where it should generally be that's good enough. With boost, you can use the AP to log that directly, so it doesn't matter much how easy/hard it is to read the gauge.
The main thing I would focus on is buying quality gauges.. MANY brands are worse than useless and give you the wrong readings, and/or fail often. Generally brands like Defi and AEM will be good.. brands like Prosport and Gloshift are a waste of money. Personally, I like the AEM digital gauges myself. Defi are great, but they certainly aren't cheap.
You didn't find a WBO2 sensor for that.yeah I found a set of all 3 for 100$,(JDM) any take on the JDM brand? an for as digital gauges go.
a wbo2 for what? and idk if it comes with one or not, if that's what your asking? it came with AFR,oil presh,and psiYou didn't find a WBO2 sensor for that.
The AFR gauge is useless without a WBO2 sensor. Literally this is what EVERYONE has been telling you.a wbo2 for what? and idk if it comes with one or not, if that's what your asking? it came with AFR,oil presh,and psi
That's the one I had, although if I were to do it again I'd have bought the Innovate LC-2.
Really? Dammit...I already bought the AEM. Anyone want to buy a new AEM UEGO AFR gauge? lol Ah well.That's the one I had, although if I were to do it again I'd have bought the Innovate LC-2.
I originally liked the no-calibration aspect of the UEGO, but found myself distrusting the reading after a few years.
yeah I found a set of all 3 for 100$,(JDM) any take on the JDM brand? as far as digital gauges go.
How many motors have you been through?My tuner told me to steer clear of the LC-2.. :dontknow:
