1 - 3 of 3 Posts
· Registered
I have a 08 WRX Ej25 and my rod bearing spun about 2 months ago and I was planing on buying a brand new OEM short block from my Subaru dealer but I need little more input about if I need to buy Short block or long block when the rod bearing goes or is something you see after when you open then engine? The subie had 117k and just recently put a new turbo in march, changed clutch at 95k and timing belt at 105k so I really wanna fix it and have the car run another 100k after ,there were no after market parts only a SPT catback exhaust from my friends 09 WRX and that it, thanks for any advice in advance
· Premium Member
You don't NEED to buy new heads to go with the new shortblock. If you retain the old heads they will need to be fully disassembled, thoroughly cleaned, inspected for damage (cams and journals), and rebuilt. As long as the work is done properly it should be just as reliable as if you were to buy an entire long block. Getting the heads rebuilt will be the cheaper route, but you have to be sure whoever you have doing it really knows what they're doing.
· Registered
Discussion Starter · #3 ·
Thank you yea I just want to be sure, and I will have my friends dad work on it he has worked and fixed quiet a few engines , I would like it to have if it done at a Subaru performance shop but it costs as much as the cars value so I really can't afford it
1 - 3 of 3 Posts
