1 - 9 of 9 Posts
Hey guys, while driving my 2002 WRX normally its fine. But when I launch hand and start making high boost at high rpm there is a shake in my car. I can feel it in the shifter, in my seat and in my steering wheel. Im not sure what it is and would like to get it fixed before I begin putting more power in it. The only things that are done are a Tomei M7760 turbo, 3 inch down pipe, 3 inch exhaust and a 2006 Forester XT 5 speed transmission and clutch. Any ideas?
Discussion Starter #2
Im not sure if its related, but when I am in it hard, right when i go into 3 it seems like something is slipping as soon as the rpm's get to about 3500 they jump really quickly to 5000 without a huge change in mph, the same is said for 4th gear.
Sounds like your clutch is going. That may be the source of the vibration.
The clutch was brand new when i bought the car. Its still firm and catches perfectly. I was thinking Im over powering the clutch.
I assumed you weren't using a Forester clutch with those mods. If you used the stock Forester clutch then yeah you're definitely overpowering it. Why didn't you put a different one in there when you put in the tranny?
The shaking and slipping are two separate issues. As for slipping and putting in a 6 puck clutch, you may end up breaking other things like gears or axles if you have too strong a clutch in there. The vibration could be the bearing. You haven't described the behavior clearly enough to really understand what the car's doing.
Discussion Starter #9
When im driving normally its perfectly fine. But when I get it hard and start making power and shifting at higher rpms there is the shake that occurs especially when i put it right to the floor. the higher it revs the worse the shack is. Any better?
1 - 9 of 9 Posts
