1 - 2 of 2 Posts
Need some serious guidance. Just installed the white line adjustable rear sway bar, white line adjustable rear control arms and white line adjustable end links on my 2015 STI.
For some reason now the car has EXTREME rear end sway. Similar to riding on a flat tire or iced roads. Torqued everything down twice! End links are close to the same length as the stock links. Everything torqued at normal ride height. Tried riding on both the medium and hard stiffness but no luck.
Am I missing something here? Or is this sway bar/control arm kit not that good?
If it makes a difference, I’m also riding on the Ohlins coil overs.
Could really use some help.
Thanks
Take the bar off completely. Does the problem go away?
Put the bar on full soft. Is the problem reduced?
1 - 2 of 2 Posts
