1 - 4 of 4 Posts
I have an 06 wrx and i have removed the secondary air pump by installing blocking plates on the heads and deleted the dtc codes off the ecu map... Will i have trouble passing the ob2 portion of an emissions test? I live in Utah which doesn't require a visual inspection. If it is at normal opperating temperature will it still not pass the ob2 readiness check?
Romraider allows you to "Force Readiness Monitors". If you're concerned, pull your map, select that option, reflash.
1 - 4 of 4 Posts
