1 - 7 of 7 Posts
Anyone Try that sea foam stuff out? Changed My Air pump, Car still had the engine codes - Took my engine apart and found both of the check valves are gross - Assuming all the lines to them are gross also so I'm buying new check valves and wondering if there is a way to clean carbon build up through the system Without replacing everything
In Æternum
Yes. Seafoam is a staple of my diet.
I just used a can with one of my bikes the other day.
Super Moderator
Seafoam is essential with small engines. I use it in the mower, snowblower, scooters, and generator. I've never used it in a vehicle engine. I've used Lucas top end cleaner in the OBXT and 4Runner. Probably should dump a bottle in the Cruiser, too.
1 - 7 of 7 Posts
