1 - 19 of 19 Posts
I can't believe what a good deal I just got. This thing looks absolutely brand new - but I need hardware. From what I can tell, the two mid-pipe sections are bolted together already. What else do I need? 4 bolts, 4 nuts, 2 flat gaskets, and a 2.5" donut gasket?
Obviously, I have no instructions so any quick guidance is much appreciated.
Awww no burnt tips :( sounds like you listed everything you need, its a pretty simple bolt on
I'd also get a set of hangers.I needed XL hangers for mine.
Comes with 3 pairs of bolts.1 pair 12mm for DP to midpipe.Other 2 pairs are 14mm
Sent from my HTC PH39100 using Tapatalk 2
I believe the two gaskets that your needing are both just 3" 2 bolt collector gaskets
What about donut? Just use stock one?
Did I mention I got this for $350 :tongue:
No you dont use the donut, the exhaust doesnt seal right to the downpipe. The downpipe is a flat flange so just get a 3" gasket they are cheap.
will the stock hangers not work? or is it just for dropping the muffler down a little
Whaaaat? $350?? That's crazy man! Great pick up dude.
The stock hangers will work, I just don't like messing with my exhaust and I like it to stay put so I buy urethane hangers.
Discussion Starter #11
Quick question. If I'm not using donut, only flat gasket to the downpipe, do I still use spring bolts? Or just use regular nut/bolt and torque it down?
Discussion Starter #14
Sorry guys, mine did not come with any nuts or bolts - otherwise, I would know what to use.
The problem I'm running into is that everything seems short! The big bend by the rear axle is rubbing against heatshield and the tips are so recessed that the muffler is pulling out of all the bottom hangers. Wtf? I spent two hours and I can't get this close to lining up.
Hook up one of the upper hangers,then onto the other upper hanger on the other side and then onto the lower hangers.
Should go on without any problem.I took off mine & put it back on without any problems.
This
Its been a while on this thread buy im buying this catback for my
2012 wrx do i need to buy hangers? Or will
Stock work? I have a sedan also
1 - 19 of 19 Posts
