You should test all 4. I believe around 120 is normal for a closed throttle plate test so 115 wouldn't be terrible. It's within a few percent of the 120.
You should look for boost or exhaust leaks. Also clean the maf sensor and dump the k&n filter. They tend to blow the oil used to capture dirt into the MAF sensor throwing off scaling
