Aftermarket MAP sensors will require recalibration of the ECU. If you're not comfortable / able to make said changes, you should replace it with an OE unit. Otherwise, you could run into serious issues with your vehicle.
Are you able to calibrate the ECU to account for the aftermarket MAP sensor? My brand recommendation means nothing if you're not; you should be reaching out to the person tuning the vehicle and find out what they want you to install.tox23 said:ok thank for the advice ! and for brand perrin and Omni Power ?
