1 - 18 of 18 Posts
Not sure if this is the right place to post this thread, but Ill post it anyway please correct me if im wrong admins. So everyone knows about the S206. I was wondering if anyone knew how to order the s206 rear bumper running/brake light. I dont know even if its possible but let me know please thanks.
^^ What they said.
Exterior Modification thread would've worked too, but this is fine :D
Discussion Starter #10
Not the best option out there.But you can get it from your dealer or any Subaru parts dealer.
So what would you rec. The only reason why i was was thinking about getting it was because it comes with everything to plug it in and your done. Not that simple but at least you dont have to cut into wiring or tap into the wiring.
Defi Racer Series
+ 1
Defi stuff is pricey, but the gauges are high quality, work well, and look great.
Sent using Tapatalk
I second this.
I don't know if Subaru fixed this but the SPT boost gauges that came with the first batch of 2011s were defective.
If you use an add-a-fuse you don't have to tap into any wires.
There are different options available.Defi is great.Also try AEM & prosport.
I have Prosport premium gauges with the smy cluster.
¯\_(ツ)_/¯
On that note, you might check out MadDad gauges as well. I've heard good things about them, and they are color matched to the 2008+ OEM gauge clusters, which is nice.
I personally haven't tried them, but the reviews I've read were positive, they just aren't as well known as AEM, Defi, etc...
Sent using Tapatalk
1 - 18 of 18 Posts
