1 - 14 of 14 Posts
im kinda new to turbo cars, and the wrx, but ive noticed that when i get into any kind of boost and i engage the clutch and let off the accelorator, i notice the rpm jump 200 rpm and come back down right before i shift. it seems to be in conjuction with the bov recirculating the air. i notice that the bov and the 200 rpm blip happen at the same time. is this a problem? or is this just what happens when u recirculate 100% back into the intake.
any help would be appreciated
ps. im stock with 488 miles. still in break in process. :confused:
Mmmm. I notice the same thing.....I am now used to the car and it either doesn't do it or I am used to it......I know what you mean though :)
Discussion Starter · #3 ·
Re: Re: Rpm Blip
thank goodness. cause i seriously didnt want my car to be the only one doing that. i was like...20 views? and no one knows what im talking about..geez whats wrong with my car!!! if its something that everybody has..then im sure ill get used to it. its just annoying when i shift at 4k and the thing jumps to 4200 and i know i just broke one of the sacred laws of the crucial break in process.
Re: Re: Re: Rpm Blip
I kinda think they all do it. Perhaps it's the turbo just continuing to boost until the bov takes over....to be honest I rarely notice it now if at all.
Cheers
yeah mine does that too, mostly when I do partial throttle or when I shift while the turbo spool up. Next time just let the turbo spool first then shift and it wouldnt do that, well at least on my car.
Mine does it too!!!
I assume it was the last bit of boost before the BOV cuts in.
Thats my speculation.
If anyone can offer a legit explanation I'll take it :)
Cheers
Antony
Discussion Starter · #8 ·
it only happens when im making boost and not when im in vacuum. all i do now is just let off the accelorator and wait until i get into 0 or -negative pressure and shift.
BoostedAWD,
Is that really necessary?
200rpm is all that I experience in the overrev.
There isn't much point on the stock car going past 6krpm due to the severe power drop off so you aren't even going to get near the revlimiter.
Theres no harm in it. Just a weird phenomenon to get used to.
Cheers
AntMan
Another few degrees around and you've nearly got the same angle as my avatar ;)
Cheers
AntMan
Since the turbo is literally forcing air into the intake, you have to make sure your right foot is COMPLETELY off the throttle before you disengage the clutch or you will get the blips. It took me a while to figure it out and a little longer to train myself to lift my foot a little more for upshifts. If I get lazy, it'll start doing it again.
-Jim
1 - 14 of 14 Posts
