1 - 9 of 9 Posts
Do your struts not have the white sticker near the bottom? I'm pretty sure this has an LH or RH designator on it. Also you should be able to compare them to the struts that you are taking off and figure things out.
If they are not labled just take a strut out and see what strut it matches before you put them in. The difference in the brackets is quite obvious you cant really accidentally put them in the wrong place as the brake lines and abs sensor wouldnt bolt up right
1 - 9 of 9 Posts
