1 - 9 of 9 Posts
Does anybody know how properly reset the ecu?? Did search but couldn't find any!! Thanks for your help!!!!
Me too! Is there a fuse or relay that can be pulled, instead of disconnecting the battery?
God said:
I just put my foot on the brake pedal and turn the car on and off 5 times.
Cool, thanks. Is that in the manual? Must've missed it...
Moderating U!
I think what Dan means is to take the negative battery terminal off of the battery post. Then get into the car, and press the brake pedal for about 5 seconds to clear all of the electricty out of the system. Then re-install the negative battery terminal. The ECU will be reset. Then drive the car like you stole it, or search on here for the Shiv ECU quick learn method. This method really works.
Moderating U!
God said:
Actually no, if you just wat to turn off the light on the dash, you can just turn car on and off 5 times with foot on brake. Voila, off (unless of course, you have an ongoing problem).
Oops, sorry. I might have to try this one since I get self induced CEL's from my Vishnu Unichip sometimes.
1 - 9 of 9 Posts
