1 - 6 of 6 Posts
I can't get the roll pins back in for my new shifter linkage knuckle, my mechanic friend advised me to just put a bolt and lock nut in its place, it seems to have no slop and work fine for now.
But I've been reading that it can be bad for a variety of reasons. What is your opinion on this? Thank you!
Sent from my VS986 using Tapatalk
Super Moderator
Use a roll pin. They are solid and spring steel so they won't wear out. You'll quickly wear the major diameter of the thread down because it's thin and cause slop.
Water.....sometimes waves
^^ this. Bolt will work 4 a while then wear away. Also bolts not made for "shear" applications.
Squeaze pin in with vise grips or tap it in, put it in freezer 4 a while first then work quick once taking it out. Warm the linkage if possible just prior.
Discussion Starter · #4 ·
I ended up putting a screw with a lock not... Will take your advice and put a roll pin when I get access to lift again.
Could the bolt actually fall out and leave me disconnected while driving?
Likely not fall out with a lock nut. But it could just snap off at any time and fall out. It depends on how hard you shift, what type material bolt u used, and how many shifts u make as to when it will fail. Its just a gamble...
Super Moderator
I hope you at least used a shoulder bolt.
1 - 6 of 6 Posts
