1 - 3 of 3 Posts
My car has an STi scoop, but I need it repainted.
So what's involved with removing and installing it again, I couldn't find directions anywhere. Thanks!
It's actually quite easy - open hood and prop it open. unscrew the metal hood scoop plate (there is a hidden screw underneath the yellow cloth on either side of the scoop). I think at least one of these is a plastic retaining screw. You may have to watch out for the intercooler spray hoses. After that's off, then you can unscrew the hood scoop nuts and remove the scoop.
Try this link:
http://www.scoobymods.com/forums/showthread.php?t=235
Not quite sure where all the pics went, but the directions should give you a better idea...
1 - 3 of 3 Posts
