I'm not sure if this has been touched on as a thread yet so here it is, delete if it has:
Cars affected:
2007-2009 Legacy (Turbo)
2007-2007 Outback (Turbo)
2008-2014 WRX/STi
2009-2013 Forester (Turbo)
Part Recalled:
Secondary Air Pump Relay
Part Number: 25232AA090
Service Description:
Relay is inspected and replaced. Secondary air pump is also inspected and only replaced on an as need basis.
If you already did the secondary air pump delete then this recall does not affect you. The relay has been shown to malfunction and will allow the pump to operate continuously. When this occurs the check engine light will illuminate. The continuous operation of the pump causes it to overheat and in cases begin to smoke. The service is claiming to take roughly 1 hour so long as the air pump doesn't need replaced. This time was quoted by my dealership. Time to remedy could change from location to location.
Here is the PDF: https://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM546139/RCRIT-16V738-2254.pdf
Cars affected:
2008-2014 WRX/STi
Part Recalled:
