The EJ motor is known for pretty excessive blow by oil. The sure tell way to check this is to remove the intercooler, and see if there is oil in the TB hose, or the hose going to the turbo from the intercooler. If so, the best way to eliminate this is a quality Air/Oil separator. I prefer the IAG one, but the Crawford one is nice too.
Also, this tune you are reusing. I am guessing it is from your car before the built motor? If so, it should be retuned.
First and foremost, check for blowby oil like mentioned above. If there is some and you invest in a AOS, give it about a thousand miles and all of the blow by should be cleaned up. If after installing an AOS and you can still notice oil being burnt off a good bit, investigate further into other reasons, like the turbo seal.
