1 - 9 of 9 Posts
My WRX is stock except for 17 inch wheels/tires. I am considering buying a rear sway bar (probally Cusco adjustable). My question is will my car feel any different when I am driving in the city? If so, is it a really big effect, and what are the differences?
Thanks
To give you a simple answer: Yes.
It all depends on how hard you push your car. I installed a rsb (adjustable at 24mm for now) and have noticed quite a bit of handling difference. I can get a more neutral feel out of the car now, and the back end definitely slips out more under hard cornering when I lift the throttle mid-turn to initiate oversteer. I don't push hard often on the street, only on a few deserted corners on the way to work.
I will probably back the setting down to 22mm after my autox this weekend (in prep for rallyx the next couple weeks), then down to 20mm for winter. I don't think I'll need more oversteer once the snow hits the ground.
Jay
Moderator
is the rsb easily adjustable/installable on your own? what tools are need to adjust and which are needed to install. im also planning on ordering a rsb soon.
-c
It is pretty easy to install. Now that I've done it once I can probably adjust it in <10min. A friend said "It will probalby take you less than a half hour if you are eating your breakfast and taking your time while installing the bar" It took me probably 20-30min to put it on. All you need is a few wrenches, I think in the range of 12mm to 16mm or so. Not sure exactly what wrenches you'll need, but if you have a socket set and a crescent wrench you'll be fine.
Jay
Moderator
thanks. do you need to jack the rear end up? or is the stock rsb accessible from underneath?
-c
Discussion Starter · #7 ·
But in normal everyday stop and go traffic will I see a handiling difference? Does it stiffen the car up? If so, is it noticeable in everyday city traffic?
Also what brand(s) are rcommended?
In stop and go traffic? No. You'll only feel the difference in corners. It's a chassis balance adjustment, not a stiffness adjustment. In a straight line you'll feel no difference.
I actually did raise mine when I did it, but the suspension has to be loaded when you do it, so I jacked it up, then lowered it down on some blocks to make it a little more comfortable under there.
Whiteline and Cusco are the most popular brands. I guess the only difference is bushings - the Cusco comes with slightly better ones.
The sway bars will help to keep the car flat in turns. I would suggest that you get the end links when you get the rear sway bar. They are a lot stiffer and amplify the effect of the sway bar. I have the Whitline front and rear with the Whiteline end links. Car is nice and flat in the turns. I will be replacing the Whiteline links with the Vivid ones soon. Look at them both and you'll see the difference. I hope to be throwing the ass-end around a little more....sliding is fun................
Check out our site, we have a lot of suspension parts, plus all the power and styling goodies.
[email protected]
480-966-3040
www.vividracing.com
1 - 9 of 9 Posts
