1 - 7 of 7 Posts
· Registered
Hi guys,
Not sure if this is the right place to post it, so I thought I'd post this here (rather than the transmission sub-forum, cause it seems so clean).
My question is - how doable is a rear diff swap on a GC generation STI (as in is it possible to change it in a driveway without a lift and without me being a pro)? And one more question - is it possible to use a rear diff, from a GC8 wrx (possibly other gens as well)?
There's this STI I'm quite interested in buying, that has a rear diff problem and I'm wondering if this issue will be a wormhole for money or not.
Thanks!
· In Æternum
You will want to use the rear diff with proper drive modifier. This means using a rear diff out of the same body style.
Sent from my SAMSUNG-SM-G890A using Tapatalk
· Not a mod... or is he? Or, is he not?
Are you pulling the entire pumpkin and putting a new one in or are you talking about pulling the carrier and replacing it? If you are getting your current one I would take it to someone. There is a fair amount of know-how to setting backlash and gear mesh.
1 - 7 of 7 Posts
