1 - 9 of 9 Posts
Chap said:
doesn't that stop the signal from going out the back of your rex???
also, where does the wire go/how'd you wire that :confused:
nope, it's still low enough to "see" out the back window. i don't recall what wire it was (i checked for a wire that turned on with the key using a meter), but i'd like to say that i tapped into the blue wire for the compass/auto dim mirror. for ground, i just used the bolt that holds the center visor to the roof.
so without the auto dim mirror i wouldnt be able to do it?
i was thining of doing something like this but i'm not sure if its the same on a rex
1 - 9 of 9 Posts
