What's The Stock Boost On 05 Wrx?
My current mods are Up and Dp, Exhaust, and CAI...
What should I go with next?
you need engine management,,, that and a protune will net you close to 70hp and 100lb ft.What's The Stock Boost On 05 Wrx?
What should I go with next?![]()
Cobb since there are more users/tuners that work with it.Nice! Do you recomend cobb or utek?
Why would it bother you?For some reason your Signature bothers me.... I-VTEC........
not that im bothered by it but i am confused by it,Why would it bother you?
well im about to take my MBC right now would it be a problem if i have it set at stock psi's with the mbc on?stock boost is about 11.5 PSI.
My personal opinion, but...drop the CAI, put the stocker back on there, and do some kind of engine management. ECU roms is the cheapest, Cobb is liked well, but there are many others. You could also upgrade your top mount if you wanted, but its not really a necessary item until you upgrade turbos.
Now if you weren't looking for engine upgrades, I could add a much bigger list.
Its i-vtec: intelligent- introduced continuously variable camshaft...not that im bothered by it but i am confused by it,what does it mean?
***13.5 PSI***stock boost is about 11.5 PSI.
yea ditch the MBC, your car would run so much better if you just get it protuned adding more parts without it will just make matters worse IMO.well im about to take my MBC right now would it be a problem if i have it set at stock psi's with the mbc on?
what cams are good for my car?
You definitely had it spelled wrong this morning.... That is what bothered me.... I-Vtec not I-Vetec...... You changed it now so Never Mind.Why would it bother you?
is this a honda discussion board?:rotfl:You definitely had it spelled wrong this morning.... That is what bothered me.... I-Vtec not I-Vetec...... You changed it now so Never Mind.
lol I-Vtec is WAY more complicated than that.... But hey whatever.
only if you want it to be, I've had enough Honda crap for this week with my little brothers caris this a honda discussion board?:rotfl:
actually your missing your restricter pill. Most of the time you don't just "blow" your turbo up, actually in most cases you will "blow" your engine up prior to the turbo. Go to a dealership and tell them you need the vacuun lines from the turbo to the wg the stock b.c. and the T, Reducer, and restricor pill, and you will boost fine.LOL! I know I caught that while I was doing lab!
Well I put my stock BC on and my boost gauge reads 6psi's...
Stupid MBC! I learned my lesson! My Turbo had blown like a month ago!
