1 - 4 of 4 Posts
new to the forumjust got my 02 wrx sunday,
so go easy on me,
and i had a problem with it the CEL light came on and i took it to the dealership and they scanned the codes and it was missfiring on #1 and #4 cylinders, the mechanic said i needed my ecu reflashed, and he said i could reflash a differant program put on that would give me more H.P.,
my question is should i have the subi dealership put this program on?? or should i go with an aftermarket one?? and if you guys know anythin about the reflashing they do at the dealerships.....
sorry for another post about ecu's but i did try to search but im not sure what the dealerships program was called,
thanks alot,
and take it easy im a Noob
-nate
Motor needs to be grounded better! Spark plugs need a good ground to complete spark circut. Make your own out of wire. Connect both heads to frame. I use solid copper wire. I have had this cel when taking out motor and trans for a rebuild and broke a ground strap.
Scott
1 - 4 of 4 Posts
