1 - 7 of 7 Posts
I own a 2013 WRX brand spanking new engine installed about 2yrs ago, pro tuned by, JRTUNE at prime motoring in NJ.
MODS on vehicle-
COBB>E85 flex fuel kit with
Fuel pressure sensor
AEM >fuel pump E85 high flow
intank fuel pump: semi universal
:eek:ffset inlet with hooks
:65MM Body length
:320LPH(84GPH)@43.PSi
BOSH : fuel injectors :id1000cc.
COBB> 3port Boost Solenoid
COBB> Intake
PERRIN> Turbo inlet
PERRIN> lightWeight crank pulley
TOMIOKARACING 18G turbo.
TIAL>38mm External wastegate with GRIMMSPEED > upPipe & dump tube.
GRIMMSPEED > Hi flow crosspipe on stockheaders.
REV 9> Front mount intercooler......
IAG> topfeed fuel rails & Braided fuel lines -6
MAGNAFLOW> Full 3” exhaust flow downpipe
FORGE> blowoff valve
OEM: TGV delete:
COMPETITION CLUTCH> Stage 2.
Wow! Outa breath. Lol.
my question is what’s the best oil to use?
have been using for the past 3+yrs is
motul oil 5W 40. Idk if it’s me, or what but my aem oil temperature seems to show it’s warming up to yellow.
just seeking for some advice.
thanks in advance guys. RUMBLE ON!!
Super Moderator
Oil temp issues may not be related to oil brand motul is highly regarded.
Into the yellow isn't really anything. What temp is it hitting? what conditions is it hitting this temp?
Draw a sample and get a used oil analysis.
Post your water and oil temperatures.
Post your oil pressures at 1k and 5k rpm.
Send all these above to your engine builder and get direct feedback.
Discussion Starter · #5 ·
Well I dnt know exact numbers of the temp, but I was just wondering if in these New York heat my oil may be too thin? Idk. 🤷🏾‍♂️
Um... well...
Then there will be no wondering.
Super Moderator
Then follow as SD_GR suggests. I'd also not consider NY hot by any stretch of the imagination, so I'd probably lean away from that particular possibility.
1 - 7 of 7 Posts
