i thought readline was 6700
I think you are using the wrong criteria here. Engines work on principles of physics and mathematics, not human senses and emotions... engine sounds like it's going.... ...it acts like it wants no part..... ...engine does not appreciate wringing...... .....easily surpassing....
Thoughts?
Yes, but when you run the RPM's out closer to redline you're placing yourself right near peak power when you shift into your next gear. Otherwise, why not just shift at 4500 every time you want the most out of your car?What's the point? Loses all its nuts at 4500 rpms anyway
You can mathematically determine optimum (acceleration) shift points by choosing RPM ranges that maximize torque under the curve. Spoiler -- it depends on which gear you are shifting through.Yes, but when you run the RPM's out closer to redline you're placing yourself right near peak power when you shift into your next gear. Otherwise, why not just shift at 4500 every time you want the most out of your car?
My point exactly. Anything above 5.6k-5.7k, while in any gear, and the engine sounds like it's straining so hard it's going to blow.i thought readline was 6700
Ha! I would say it's more like 5200-5400 rpm. Seems pointless to exceed this amount in a 2.0 liter WRX (not STi).What's the point? Loses all its nuts at 4500 rpms anyway
\I don't understand your question. You are free to rev until the fuel cutoff, which is 6600 RPM IIRC.
Touche'.I think you are using the wrong criteria here. Engines work on principles of physics and mathematics, not human senses and emotions![]()
Has anyone done such analysis on a stock WRX? While I understand there'd be slight variations from vehicle to vehicle, I'd still be curious to see approximations.You can mathematically determine optimum (acceleration) shift points by choosing RPM ranges that maximize torque under the curve. Spoiler -- it depends on which gear you are shifting through.
No sugar-coating there......
This is a long debated topic in drag racing circles and the consensus is to take it to redline, bang the next gear. However there are vehicles with extremely peaky torque curves that it's in your interest to shift earlier. With the relatively flat curve of the fa20 I'm going on a limb and assuming it isn't one of them, but depending on the gear ratios it may be.
That's pretty much what I do, shift earlier. Just wish the twin-scroll had better low-end torque. Isn't it supposed to?Hondas don't love to be wrung out. Lots of people say it, and there are lots of people who blow them up. For daily driving duty I would stick with shifting earlier if you just want the seat of the pants push.
Compared to a non twin scroll in the same application it should if all else is equal.No sugar-coating there...
